1995 Chevy Silverado Engine Surges, No Power, Doesn't idle
1995 CHEVROLET SILVERADO
250,000 MILES • V8 • 4WD • AUTOMATIC
LLTE442
I have a 1995 Chevy Z71 5.7L with 250,000 miles on it.
Truck doesn't idle well, no power, surges, and it's running extremely rich... The service engine soon light comes on after running a while. I believe the codes were "34" and "44" when we checked. One of those was the O2 sensor and the other was something on the throttle body (can't remember!!!)
I replaced O2 sensor, but not the throttle body because I saw that the timing chain was messed up I wanted to replace that first because I wasn't sure if that was causing the problems or even if that was causing any codes to come up. After the chain was installed, still ran bad. Checked the timing, the mark on the balancer was off the plate ( maybe an inch or so before the plate so that the mark on the balancer was pointing straight up ).
Do I need to adjust the timing? and if so, where is the wire to bypass the computer?
also, how I do check for other potential cause for this problem?
Thank you!!! :)
Apr 4, 2010 at 11:11 AM
THIS IS MIKE
  • 686 POSTS
Yes you will need to set the ignition timing, here is the proceedure.
1. Set the parking brake. Block drive wheels. Place transmission in Neutral or Park. Warm engine to operating temperature. Turn A/C off(if equipped). Make sure Malfunction Indicator Light (MIL) is not onl
2. Disconnect Electronic Spark Timing(EST) by-pass connector (Tan/Black wire) which is located near distributor or in cab behind glove box. Do Not disconnect 4-wire connector at distributor.
3. Connect timing light to No. 1 spark plug wire. Check timing and adjust if necessary. Reconnect EST by-pass connector. Clear Diagnostic trouble code.
Ignition timing 0 Degrees BTDC @ idle 5.7L vin K 0@idle
Apr 7, 2010 at 5:09 PM
