1995 Chevy Silverado
1995 CHEVROLET SILVERADO
JASON5640
Brakes problem
1995 Chevy Silverado V8 Four Wheel Drive Automatic
how do i get the clip off that holds the brake pedal to the push rod on the brake booster
May 14, 2009 at 1:19 AM
DR LOOT
  • 2,311 POSTS
That is a good question, it has a safety clip so it can not fall out and you lose your brake pedal, this is how to remove it: take your finger and put it on the outside of the clip then pull out a little bit and straight up that will release the lock mechanism and the clip will come out, if you ruin the clip you will have a fun time locating another one probably only at the junkyard
May 14, 2009 at 2:20 PM
