1994 Chevy Silverado windshield wiper motor
1994 CHEVROLET SILVERADO
114,000 MILES • V8 • 2WD • AUTOMATIC
1CRAIG1
/img][img:158300b8b3]http://www.2carpros.com/forum/automotive_pictures/502206_wiper_motor_94_Chevy_C1500_truck_2.jpg[/img:158300b8b3]
If wiper was installed in truck and I was looking out the windshield from the drivers seat and both these holes were horizontal, approximately where would the the driveshaft arm be located, in degrees, when the assembly was inserted into the firewall?
Mar 17, 2010 at 11:53 AM
MATHIASO
  • 1,209 POSTS
Hello 1craig1 Is the question about how to install the windshield motor in your Chevy? Remove the cowl vent grille
https://www.2carpros.com/forum/automotive_pictures/46384_0900c1528008f337_1.jpg
Disengage the wiring connector from the motor
https://www.2carpros.com/forum/automotive_pictures/46384_0900c1528008f338_1.jpg
Remove the drive link-to-crank arm fasteners
https://www.2carpros.com/forum/automotive_pictures/46384_0900c1528008f337_2.jpg
Slide the links from the arm
https://www.2carpros.com/forum/automotive_pictures/46384_0900c1528008f337_3.jpg
Remove the motor mounting bolts
https://www.2carpros.com/forum/automotive_pictures/46384_0900c1528008f337_4.jpg
Remove the motor from the vehicle
https://www.2carpros.com/forum/automotive_pictures/46384_0900c1528008f33c_1.jpg
Mar 18, 2010 at 1:19 AM
1CRAIG1
Gentlemen;
The question I asked was not answered to my satisfaction. The pictures that accompanied
the answer can be found in "Chilton's" manual (8055) 2864 General Motors
full-size trucks 1988-96 pages 6-48 and 6-49.
The reason I asked the question was that the motor was bench tested and the motor turned
thus changing the position of the original set of driveshaft. Thus the starting position
of this arm will make it more of a trial and error method of attaching the crank arm
fasteners to the motor driveshaft....which could be very time consuming?
Thanks
Mar 18, 2010 at 8:06 AM
MATHIASO
  • 1,209 POSTS
Hello 1craig1
The problem you explain happens when the motor was remove and the wiper switch was not in park.
I agree with you that it could be time consuming to get it back right..
Install it, turn the switch in park position, then remove the wipers arm and reposition them back.
Mar 18, 2010 at 10:08 AM
can i use old drive shaft connection on new winshied wiper motor
Jul 14, 2012 at 11:12 PM
MHPAUTOS
  • 31,937 POSTS
you should be able to with out a problem, if you leave the arm off an connect the motor, cycle the wipers they will self park and place the blades at park position as well, everything should line up then.
Jul 15, 2012 at 12:22 AM
CADIEMAN
  • 3,544 POSTS
im with mhp.put a jumper wire from the motor to a good ground.then with the switch in off and key on plug in the connecter the motor will run to park pos. then install and resecure the wiper linkage.
Jul 15, 2012 at 1:02 AM
