The fuses for the brake and turn signal blow. I replace the stop light fuse and the brake lights work until the fuse blows again. I replace the turn signal fuse and the turn signals still do not work then the fuses blows again. The 4 way flashers still work whether the fuses are good or not. This truck has a tilt wheel. Is there a history of the harness in the column shorting out due to the years of use of moving the wheel up and down? If you feel the source of the trouble is not in the steering column what is the most likely source of the trouble?
Mar 15, 2009 at 9:06 AM
