Keeps melting the parking lamp circuit in the headlight switch. I checked that it had the correct fuse and it does. It calls for a 20A fuse and it doesn't blow the fuse. The wire that supplies power to that part of the switch has been really hot and the wire coming out of the switch on that circuit is almost melted as well. I stuck a 10A fuse in that circuit and it did NOT blow the 10A fuse. We tow a trailer with it sometimes but all the wiring checks out and it should blow the fuse before it melts the switch if there is a short somewhere. I'm stumped! Where do I go from here? Thanks.
Jun 1, 2010 at 5:21 PM
