1994 Chevy Silverado floods out at a stop
1994 CHEVROLET SILVERADO
75,000 MILES • V8 • 4WD • AUTOMATIC
GATOR812
i have to hold down the gas to get it to restart , an some times a few times to restart ,its like a vacumee leak ,.. but i checked , i found 2 vac hoses switched around @evap purge can solenoid valve.
could this be the problem?
if not what may it be
this happends from time to time
thank you for your time !
Sep 23, 2010 at 5:52 PM
Try cleaning out the idle air control valve and test the throttle position sensor-
Sep 23, 2010 at 6:30 PM
GATOR812
i have been told that the throtle position senser was bad loooooooong time ago , or was going , how do i test it ? im a old school truck guy and computers and sensers are a learning deal for me ,..ya have plumbing questions , small engines questions ? how do i clean out that air senser ?
is the map senser a culprit?
thanks again , i like this site and plan on my wisdom elsewhere !
Sep 23, 2010 at 6:37 PM
Get a voltmeter-Test the TPS closed and wide open throttle voltages, if its bad long time ago I recommend you just replace it-
Sep 23, 2010 at 6:41 PM
