Engine firing order?
1994 CHEVROLET SILVERADO
ELMER SILVA
V8 two wheel drive automatic, what is the firing order of the plugs so I can install them correctly?
Apr 26, 2010 at 7:42 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello, Here is the firing order for 5.0L, 5.7L and 7.4L engines. Distributor Rotation: Clockwise Firing Order: 1-8-4-3-6-5-7-2
https://www.2carpros.com/forum/automotive_pictures/261618_1_161.jpg
Apr 26, 2010 at 10:08 PM
ALEX PAZ
Engine Performance problem
1993 Chevy Silverado 6 cyl Two Wheel Drive Automatic
does anyone know what the firing order is on a 93 chevy v6 pick-up eith a 4.3l engine, i also need to know the positions on the distributor cap?
Aug 9, 2020 at 12:20 PM (Merged)
https://www.2carpros.com/forum/automotive_pictures/12900_fo_36.jpg
CURTIS SIMMONS
Electrical problem
1990 Chevy Silverado V8 Two Wheel Drive Automatic
I have a 305 v8. Can you tell me where #1 firing wire is on the dist. cap. When #1d pistion is up.
JDL
  • 16,098 POSTS
https://www.2carpros.com/forum/automotive_pictures/170934_90_silverado_1.jpg
Welcome to the forum. Number one, up on the compression stroke.
BADMOFO
1989 Chevy Silverado V8 Two Wheel Drive Automatic
I was checking spark plug wires and found one lose, I don't know if firing order is correct. Can you send a diagram of firing order on chevy 350?
DCS1998
  • 41 POSTS
1-8-4-3-6-5-7-2.
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is the information you requested. I've attached a picture below of the firing and cylinder order. Hope this helps and thanks for using 2CarPros.
Mar 6, 2021 at 4:52 PM
Take a look at the attachment below for the detail on the firing order and positioning of the cylinders and distributor.
Let me know if you have questions. Thanks
Mar 6, 2021 at 4:54 PM
