1994 Chevy Silverado Back-up lights & cordesy lights n
1994 CHEVROLET SILVERADO
398,532 MILES • V8 • 2WD • AUTOMATIC
SHARP30284
I was changing the reverse lights bulbs in the third brake light above the rear window and the reverse lights and the cordesy light bulbs all popped off. Were is the fuse for the back-up and cordesy light bulbs?
Thank you for your help.....
Jul 26, 2010 at 5:37 AM
EDWARD.S
  • 166 POSTS
Hi, Look Under the Hood first, It's A Square Box With a black Cover on it. If You Don't See One Try The door Pillar,As You Open the door, Look For A Small Cover on the side of the dash,That Would open, Fuses Are in there.It could be On the drivers side Or Passengers side.
Hope This Helps You,
Good Luck
Edward S.
Jul 26, 2010 at 5:47 AM
SHARP30284
Thank you Edward ...I found the 20 amp fuse under cordesy in the fuse box and replaced the fuse.....Everything is working now.....
Jul 26, 2010 at 10:06 AM
