it seems that the bolt on the pulley that the belt rides on will not tighten??? I will go try again.
When I first started the project, I did not know how to release tension, so I loosened the bolt on the part that has the spring in it , i realized that was wrong and then tightens it. Then I found out that I needed to put a wrench on the "pulley" bolt and turn counter clockwise
So you are saying to have the belt in the correct position and then tighten the bolt that is in the "pulley touching the belt ?
thanks, sorry for the confusion(on my part)
Sep 6, 2008 at 3:23 PM
