1993 Chevy Silverado Hei computer timing
1993 CHEVROLET SILVERADO
15 MILES • V8 • 4WD • AUTOMATIC
DHILT48
Hi i recently rebuilt a motor and put it in my 93 chevy pickup, i am having problems i believe with timing. I was told a computer chip would help solve my problem, tono avail. I can start the truck it will idle fine, about 5 minutes (after warm up) it idles down almost dies, then it starts to surge. I am just about certain it is a timing problem. But i am unable to find information on how correctly time a computer controlled hei ignition system on this year vehicle.
Oh, also it is backfiring thru the tbi, i took it for a drive and at first gear it was fine, but shifting into second above 30 repeatedly backfires thru thecarburetor and will not even stay running. Thats about the extent of my problem. any help would be appreciated. thank you
Dec 13, 2008 at 11:00 AM
MASTERTECHTIM
  • 4,750 POSTS
sounds like timing problem. there is a connector under passengers side of dash where the wiring harness comes through firewall and you will see a tan with a black striped wire with a connector connecting the wires together, this is the est bypass wire, you need to unplug this connector and set timing to 0 degrees then turn off engine then reconnect the connector.
Dec 13, 2008 at 5:53 PM
