1989 Chevy Silverado how to reach solenoid
1989 CHEVROLET SILVERADO
106,000 MILES • V8 • 2WD • AUTOMATIC
EJAFFY
How do you reach the solenoid wires to take meter reading or if necessary to remove them before removing the starter unit? this is a 1989 5L Silverado. I can easily get to the two main bolts that secure starter to bell housing, but from under the truck I can not see the solenoid let along reach it. Can solenoid be reached from wheel well if small flexible cover is removed or do I have to remove the inside metal wheel/fender unit (WOW)? Installed a new battery, but when ignition key is turned to start, I do not hear anything and assume problem is solenoid. NO dimming of lights when key is turned to start.
Oct 15, 2008 at 9:44 PM
JASONRAY
  • 213 POSTS
I do this for a living and what I do when I can't get to the wires on the solenoid is, first of all, disconnect the battery. Then I take the starter loose from the engine and move it around til I can get a socket on the nuts. You may have to use an extension or something. That's a lot easier than removing body parts. Hope that works...
Oct 16, 2008 at 7:47 PM
