Transmission problem
1985 Chevy Silverado V8 Four Wheel Drive Manual
Installed new clutch assembly along with clutch master and clutch slave. Bled the system and finally got a hard peddle. When I try to shift gears I have to go all the way to the floor and reverse wont shift. Turn off the truck and it shifts fine. The first time I bled the system it shifted easier, but you still had to put the clutch to the floor. The second time i bled the system and moved the truck you had to force the truck into gear. Need Help any ideas
Jul 25, 2010 at 5:41 PM
