white smoke
CHEVROLET S-10
GIVENS86
I have a 2000 Chevy S-10 automatic with 151059 miles and it died three times this morning on my way to work and my oil gauge was low. So, I put in oil and on my way home white smoke started to come out the muffler and the truck felt like it did not want to shift. I was able to go about 30 mph without the smoke for about 15 miles, then I was able to go 60 for another 15 miles until I was going about 55 and it felt like it wanted to die before it caught itself. Did I put too much oil in it, my temp gauge was normal as was everything else.
Nov 20, 2007 at 7:03 PM
White smoke is an indication that coolant is being burn in the combustion chamber. Get the tests done below to find out what's happening.
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat,Pressure test the Rad. cap,Clogged radiator,Fan clutch,Radiator electrical fan,collaspe hoses,water pump.
Nov 21, 2007 at 12:50 PM
