Yesterday I had the intake manifold gaskets replaced on my 1999 S-10 4x4 V-6. Never had any bearing noise. Has 150K mi. No moisture in oil, no noises.
Got it back from Chevy dealer and drove it 40 mi before it broke. Engine revs went up, speed went down. Now has a bad bearing knock.
QUESTION? Can you install gaskets wrong, backwards or otherwise to restrict or block oil flow or coolant flow. The dealer changed oil and filter and flushed coolant as well. $509.00 in all. Dealer says they did nothing wrong. They want to examine it privately to double check. Should I have an independent check it out?
Aug 25, 2007 at 9:26 PM
