P0410 code
CHEVROLET S-10
DDH2420
I have an 2001 gm S-10 PU with 48000 miles and am getting a P0410 code. Which fuse and relay are they talking about and where are they located? Any other suggestions will be welcome. Thank you
Mar 26, 2007 at 11:21 AM
CHEVY22
  • 1,375 POSTS
the code you gave is for a egr insufficient flow , either a faulty egr , or a blocked egr passage
Mar 26, 2007 at 7:32 PM
WRENCHMANJIM5709
I have a 2001 S-10 with a 4.3 V-6 iit has 117K and I
have had a problem with the service engine soon light coming on. It first threw a code of 410, repalced the air pump and reset the computer it threw the code again, I discovered the vaccum line to the air control valve was bad< replace line and reset Computer, Now every so often it sends the same code. Could old O2 Sensors Be causing this?This truck is A LS
Jun 7, 2007 at 8:41 AM
BIG S-10 RICK
  • 11 POSTS
had same code on my 2001 s-10 4cy.the air contol valve was bad.replace that.pick up use air pump it has the valve. :lol:
Nov 11, 2007 at 5:11 PM
