1996 S-10 2.2 FWD. The oil pressure drops down to very low or zero and I hear a rattle, as soon as I step on the gas it rises and the rattle goes away. I replaced the sending unit, Changed the OIL to a thicker grade, and replaced the pulley, What else could it be? If it is the pump I have to pull the engine. which I have no money for. Is there anyway if I have to replace the pump or clean the screen,can I do this without completely dropping the pan? Will there be enough clearance to do this?
Help!!
Help!!
Nov 29, 2007 at 11:58 AM
