oil filter location
CHEVROLET S-10
SLOTH702
i have a 1993 s10 blazer V6 4x4 that i recently tried to change the oil on. i cannot locate the oil filter for the life of me, am i missing something? i had an earlier model years ago and the filter was easily accessible through the wheel well. i have looked all over for the oil filter but cant seem to find it. can anybody point me in the right direction?
Aug 22, 2007 at 12:56 PM
MIKE H R
  • 3,094 POSTS
Sure, the oil filter is remotely located under the hood on the drivers side or on the engine. They also put it near the core support. Drain the oil in the pan first then use a bunch of shop towels to help with mess or the filter is under the drivers side of the engine, diagram (below)
Aug 22, 2007 at 2:02 PM
ILOSTMYCOOKIES
Engine Mechanical problem
1998 Chevy S-10 6 cyl Two Wheel Drive Automatic 195600 miles
where is the oil filter on a 1998 4.3 vortec s10 excab, i spent over 3hrs looking for it and still cant find it... please help!!!
Feb 6, 2017 at 2:46 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
Front under truck locate the access door in the undercarriage cover under the radiator Not located on the engine
DARREL SCATURRO
1996 Chevy S-10 6 cyl Two Wheel Drive Automatic 117000 miles
i can not find the oil filter on my truck
Feb 6, 2017 at 2:47 AM (Merged)
BUDDYCRAIGG
  • 2,262 POSTS
i think it's remotely mounted.
as in, it's not on the engine block.
look in the front corners under the hood, behind the headlights.
JOHN E JOHNSON
Engine Performance problem
1993 Chevy S-10 6 cyl Four Wheel Drive Automatic 200000 miles
WHERE WOULD THE OIL FILTER BE LOCAT ON THE TRUCK
MERLIN2021
  • 17,250 POSTS
Have a look at the left front fender area...
MLINTON
On my 93 S-10 blazer with a 4.3 V6 it is a remote filter located under the air cleaner behind the driver side headlight. Have to move the air cleaner to change the oil filter.
TEAMINC
2002 Chevy S-10 6 cyl Four Wheel Drive Manual 66,000 miles
I am trying to change out the oil filter but cannot locate it. Can you help?
SWILLIAMS
  • 597 POSTS
Oil filter is located behind an access door under the front steering cover panel. Look for the panel straight back from the center of the bumper. You need a straight blade screwdriver or a penny or even the back of a knife blade to turn the release screw 1/4 turn the panel hinges down and the filter is up in behind it. be aware that it lays flat and WILL leak oil on you if your under it. While your changing the filter wipe down the connection where the oil lines join the filter block and check the crimps for leaks.
TADDY40
where is the oil filter located on a 2002 chevy S10 and how do i go about removing it?
Jul 17, 2017 at 7:00 PM (Merged)
FIXITMR
  • 9,990 POSTS
behind alternator. there are several different tools available for this job. filter wrenches is what they are called. whatver style best works for your application. the filter is screw/twist on type.
KENTUCKYDALE
2003 Chevy S-10 6 cyl Two Wheel Drive Automatic 81000 miles
Where do I find the oil plug on the Chevy s10? I found the oil filter but not the plug.
PEAR69
  • 1,482 POSTS
It's in the bottom of the oil pan.
