Fuel Pump Not Working
CHEVROLET S-10
GASJOCKEY
1999 Chev S10, 4.3L, 175,000km, 2wd, auto.
I just purchased the truck, was told it needed a new rad and fuel pump, it didn't start when it was damp outside.
I drove the truck a couple of days, then changed the rad, fired up the truck and changed coolant.
I then changed the plugs, wires (identified each, should not be any problem there), cap & rotor.
Truck would not start, it was late in the evening and somewhat damp.
The next day, I checked fuel pressure on the line, 0 reading. then checked fuses (OK), changed relay with several others from the fuse block (no change).
I then pulled the bed to work on the fuel pump. There are seven wires @ the tank, four to the pump/gauge assembly and three to another block??. Voltmeter shows 5.14V on one gauge terminal and the same on the gray wire on other block, no voltage to pump. I then ran direct from the battery to the pump, +positve to the gray wire, -negative to the black wire, pump did not work. Help!
Steve
Hamilton, On
Sep 16, 2007 at 8:14 PM
[quote:308f1bc038="gasjockey"]1999 Chev S10, 4.3L, 175,000km, 2wd, auto.
Steve
Hamilton, On[/quote:308f1bc038]
If you feeding it with direct battery power and not coming On its dead
Sep 16, 2007 at 9:09 PM
