front end problems
CHEVROLET S-10
BAKERBALL
I drive a 1997 2wheel drive automatic 4.3 l extnded cab. The problem is I had to cange the brake pads due to the sqeeking. I put standard pads on and fixed the problem, keep in mind the rotors were smooth no groves. About a week after I changed the pads every now and then when I brake I have a grinding sound. Not a sqeek or realy like the rotors are warped but a grinding metal to metal ,I took the wheel of and the pads are sucured in place. The noise doesn't happen all the time, sometimes I stop with no noise at all
May 24, 2007 at 5:22 PM
BOOTDOG
  • 665 POSTS
having a smooth surface on the rotors and new pads put on, what you're hearing is the metal fibers inside the pads grinding against the rotors. semi metallic pads will do this. i can't remember the name of the product, but there is a chemical you can put on the friction surface of the pad that will absorb in the pad th stop the noise. try looking for it. i only know of one company here in virginia that sells it so it might be hard to find. send me a message if you can't find it and i'll call the company that has it to find out the name. other than that, it's just noise don't worry about damage.
May 24, 2007 at 6:48 PM
