Engine Code 32
1932 CHEVROLET S-10
MOJOALA
  • 5 POSTS
1994 S-10 Blazer.
I Got the 32 code which means, EGR valve circuit.
Assuming I have to replace the valve, what is next on the list if I am still having the problem?
Are there other things to consider outside the valve such as sensors?
Oct 20, 2007 at 9:45 AM
MOJOALA
  • 5 POSTS
235000 miles
This morning the "Service Engine Soon" light is gone.
Car is acting up. I don't have much brake power. It's is an intermittant problem.
while engine running(badly) I disconnected the big vacuum line to the booster, engine performance improved. I clogged it with my thumb, the engine shut off. I restarted it and put the hose back on the booster, it wanted to nearly stall again.
any ideas?
Oct 20, 2007 at 10:12 AM
