Can you tell me how to remove the windshield wiper arm from the drive Sprocket on the drivers side of the windshield?.
Feb 23, 2008 at 8:42 AM
MERLIN2021
CERTIFIED EXPERT
Here is the instructions and diagrams to help you change the wiper arm out. I would apply pressure then shock it with a hammer. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Feb 23, 2008 at 8:50 AM
CARGUY51
MEMBER
Thanks for the Reply. I love this site
Feb 23, 2008 at 8:59 AM
MERLIN2021
CERTIFIED EXPERT
Good to hear, please use 2CarPros anytime we are here to help.
Feb 23, 2008 at 9:53 AM
BLACK_0726
MEMBER
1 POST
How to tighten loose windshield wiper arm on 2000 Chevy s-10?
Oct 14, 2020 at 1:38 PM
(Merged)
JIMMYJAMES
MEMBER
When you say "wiper arm" I take it the windshield wiper arm attachment to the wiper transmission the spline where the wiper arm attaches to area is loose. The wiper arm needs to be clocked 90 degrees then fully depressed onto the wiper transmission. When the arm is fully engaged to wiper knop it should click and fold down to the vertical position. If wiper arm has a nut under a cover on the wiper arm simply tighten it if your in proper alignment. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
(Merged)
D3WITT
MEMBER
1 POST
The driver's side wiper arm just stopped working. The passenger side still works fine, and it seems that the motor is still running. Could the wiper arm be stripped or would it be the cam it attaches to? Also, how do I remove the wiper arm without damaging anything...I pulled and wiggled and it won't budge, is there a retainer nut?
(Merged)
2CARPRO JACK
CERTIFIED EXPERT
The whole end is the cover, under it there wil be a nut. Sounds like the arm broke the pivot bushing, no big deal to fix
(Merged)
KOOLBREZ12
MEMBER
1 POST
On a 1998 chevy s-10 truck how do u remove the windshield wiper arm ?
(Merged)
HMAC300
CERTIFIED EXPERT
if it doesn't have a bolt or nut holding it on there may be a little lock that will come loose. If not that then it will just pull off but that is better done with a tool to take it off or a flat screwdriver to help pry it off.
(Merged)
ROSCOE52
MEMBER
1 POST
I would like to remove wiper arms to take off body panel underneath. My seal around hood arms are leaking
(Merged)
MASTERTECHTIM
CERTIFIED EXPERT
pull the arms up then look at the base of the arm there is a little hole that goes straight through. put a nail in it or cotter pin. then let pressure off of arm and wiggle it, it should pop off. hope this helps
Oct 14, 2020 at 1:39 PM
(Merged)
JAMIE614
MEMBER
if that does not work there may be a tab lift arm look for a little tab on the side of base pull that tab out it does not move very far that will hold the orm in the air then wiggle see if it comes off
(Merged)
SISKO89
MEMBER
I need to replace the windshield wiper arms.
How do the windshield wiper arms come off?
(Merged)
CERTIFIED EXPERT
There are two ways they can be secured. One is by a bolt under a cover where the wiper arm is attached. The other has a slide clip that is at the base of the arm. Is will slid open and then the arm can come off.
