2003 S-10 Fan Clutch Bolt Removal
2003 CHEVROLET S-10
CHEVYENTHUSED
4 cyl. 2.2 L, 2003 S-10, with 103,000 miles. I need to replace the water pump and I have Chilton's repair manual for my vehicle, but the description to remove the fan clutch is vague. I need to know how to get the fan clutch bolt loose. Everytime I try the fan spins along with the pulley and water pump. Any assistance would be greatly appreciated.
Aug 24, 2007 at 2:47 PM
MERLIN2021
  • 17,250 POSTS
Take a hold of the blade...and use a box wrench...If need be loosen bolts while fan belt is still on!
Aug 24, 2007 at 3:30 PM
CHEVYENTHUSED
[quote:e264cdb5fc="merlin2021"]Take a hold of the blade...and use a box wrench...If need be loosen bolts while fan belt is still on![/quote:e264cdb5fc]
To undo the one big bolt, the four bolts, or all the bolts? I already undid the four bolts, but can't get the big bolt.
I really appreciate the assistance. Thank you for replying.
Aug 24, 2007 at 3:36 PM
MERLIN2021
  • 17,250 POSTS
If your trying to take the fann off, start pullin! I'm showing You this photo, I don't know what youve removed...but this shows 3 bolts secuing the fan...4 securing the blades to the clutch...
https://www.2carpros.com/forum/automotive_pictures/62217_Waterpump_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_Blades_1.jpg
Aug 24, 2007 at 3:57 PM
CHEVYENTHUSED
I got it off. Thank you again.
Aug 24, 2007 at 5:41 PM
