2003 Chevy S-10 Removing front brake rotors
2003 CHEVROLET S-10
50,000 MILES • 6 CYL • 2WD • AUTOMATIC
WAYNECICALA
The rotors are attached to the axle. After the caliper is removed, how do you remove the rotor?
Apr 9, 2010 at 10:39 AM
BLUELIGHTNIN6
  • 16,542 POSTS
once the brake caliper and pads are out of the way then the rotor just slides off..if it seems stuck you will need to jar it loose with a rubber mallet, beating in between lug studs
Apr 9, 2010 at 11:57 AM
