2002 Chevy S-10 Water Leakage
2002 CHEVROLET S-10
108,000 MILES • 6 CYL • 4WD • AUTOMATIC
JRAMSEY6
I have just replaced my radiator and still continue to have a lot of water leakage and have to refill the tank after every drive. My engine also wants to over heat can you tell me what the problem might be?
Oct 17, 2009 at 5:07 PM
Can you tell where the leak is coming from (aprox area)?
Oct 17, 2009 at 5:13 PM
JRAMSEY6
radiator is new hoses are good seems to be leaking from the bottom middle area
Oct 17, 2009 at 5:21 PM
I need you to check something. On the underside of the water pump, there is a weep hole. When the bearing or the seal goes bad in the pump, coolant will leak from there. Is is a small hole (aprox 1/4" in diameter). Check it to see if there is evidence of a leak from there.
Let me know what you find.
Oct 17, 2009 at 11:53 PM
