2002 Chevy S-10 Runs hot
2002 CHEVROLET S-10
141,000 MILES • 6 CYL • 4WD • AUTOMATIC
TERRYALLEN7424
only runs hot if i use the air, im thinking its needs a aniti freeze flush. what you suggest?
Jul 21, 2010 at 11:02 AM
HMAC300
  • 48,601 POSTS
if the temp gauge goes all teh way to hot then you might try a flush. there are coolant additives to add to the radiator and make it run cooler. Check to see if the fan is working when the a/c is on as it should be. if it's not then check the fuse and relay to see if it's good or not. then go through your other coolant system checks.
Jul 21, 2010 at 3:05 PM
