2002 Chevy S-10 distributor squeaks off and on
2002 CHEVROLET S-10
60,000 MILES • 6 CYL • 2WD • AUTOMATIC
NENGELS3
  • 5 POSTS
My distributor cap squeaks off and on. Could you please give me some insight as to what may be causing this? Thanks
May 13, 2010 at 6:16 PM
HMAC300
  • 48,601 POSTS
it may be loose
May 13, 2010 at 6:39 PM
NENGELS3
  • 5 POSTS
[quote:06eb6685c9="hmac300"]it may be loose[/quote:06eb6685c9]
It doesn't seem to be loose. Could it be a bearing or some other part inside it?
I appreciate your help.
May 13, 2010 at 6:55 PM
HMAC300
  • 48,601 POSTS
there is a bushing at the top and bottom. you might try to spray some penetrating lube as near the shaftand below the reluctor. that is the only part that spins inside the distributor. YOu might also changing your rotor inside the distributor as maybe the spring has come loose that holds it in place. Other than that without looking at it it's hard to say..
May 14, 2010 at 9:39 AM
NENGELS3
  • 5 POSTS
[quote:2560533e5d="hmac300"]there is a bushing at the top and bottom. you might try to spray some penetrating lube as near the shaftand below the reluctor. that is the only part that spins inside the distributor. YOu might also changing your rotor inside the distributor as maybe the spring has come loose that holds it in place. Other than that without looking at it it's hard to say..[/quote:2560533e5d]
Thanks for your reply. Bless your heart. We'll try those ideas and hope one is the answer....thanks again.
May 14, 2010 at 10:18 AM
