The tail light on my s-10 works but the brake light and turn signal on my rear left side still do not work. So it's not a ground problem. I checked the fuses under the the hood and the fuse is not blown. I tested the fuse housing with an electrical tester while I had the signal on and still did not get a reading. My problem is somewhere between the fuse box and the relay signal itself. What are all the possibilities that it could be?
Dec 27, 2008 at 10:13 AM
