Recently had the gas tank and fuel pump replaced. Plugs, wires, cap are not that old. Went for an inspection and failed with these trouble codes:
P0128--seems to be reocuring--already replaced the coolant temp sensor once.
P0155
P0300
I do need to replace the gas tank filler neck valve as it may be leaking but not positive. Would a leak cause the above 02 sensor codes to happen? Not sure if I should start by replacing the o2 sensors or start by replacing the filler neck valve.
P0155
P0300
Mar 20, 2009 at 5:43 PM
