2001 Chevy S-10 Loose heat as time goes on
2001 CHEVROLET S-10
21,000 MILES • 6 CYL • 4WD • AUTOMATIC
CDE
I have an 2001 4 wheel drive crew cab s10 and I have a heating problem. When I put on the high heat it starts off warm but then after around five minutes you can fill the heat going cold. Once the air coming from the heater is cold, it never goes back to warm.
Feb 6, 2010 at 2:59 PM
NEW 2 S10S
mine did the same turned out to be leaking water from the pump as water got low heat quit
Feb 11, 2010 at 3:55 PM
