2001 Chevy S-10 I got fuel pressure to injectors but inject
2001 CHEVROLET S-10
55,000 MILES • 4 CYL • 2WD • MANUAL
CHITO300ZX
I put my truck on a scanner and it said it was the fuel pressure sensor, I got that fix and now nothing shows up on the scanner. My truck start quick with starter fluid. My truck is body drop and the cab been replace. There is pressure to the injectors and with 55k miles on motor they should work. Do u think my computer not triggerin the injectors? do i need a computer? or is it true they have to be program and how would i find out if my computer isnt already program? i hate do spend money on something that already works. Can you please, please help me figure out the problem? your my only hope Thank,
Juan
Jan 22, 2009 at 1:28 AM
Check the actual fuel pressure with a fuel pressure gauge designed for your fuel system and comeback with the readings this is where we start.
You could be right on the computer injector ground drivers. Do you have power on the injector harness?
Jan 22, 2009 at 6:08 AM
CHITO300ZX
i replace everything almost that has to do with fuel i got pressure. I had it ran on a computer and a p1632 came up known as a thieft fuel disable. How can i make it work?? what part moreless should i replace?
https://www.2carpros.com/forum/automotive_pictures/305925_t4_1.jpg
Jan 27, 2009 at 4:02 PM
i got pressure.
What was the fuel pressure readings?
Jan 27, 2009 at 7:18 PM
