2001 Chevy S-10 clutch will not disengage
2001 CHEVROLET S-10
25,000 MILES • 4 CYL • 2WD • MANUAL
PIERCEBUNCH
iwas driving home the other day and my clutch suddenly engaged and now will not disengage i have a lot of pedal and back pressure on the clutch as normal but can no longer shift at all please help
Feb 13, 2010 at 3:35 PM
MANNY AGUON
I have the same proplem but I think that I just need to bleed the system again cause when I got the truck it didn't have any fluid in the system so try that...
Feb 7, 2012 at 1:03 AM
MIKE H R
  • 3,094 POSTS
Check the slave cylinder for fluid, If it has fluid the cylinder itself could be bad or the pressure plate. If it is empty there is a leak , check to see if is is leaking into the housing. you will still need a slave cylinder and possible the clutch plates if they have too much fluid on them.
Feb 17, 2012 at 3:52 PM
