2001 Chevy S-10 Brake light, ABS light stays on
2001 CHEVROLET S-10
32,000 MILES • 6 CYL • 4WD • AUTOMATIC
HARLYRALF
On my S-10 pickup, The same thing occurs every morning. I leave for work with no problems but once i stop for my coffee, i get back in the truck and the brake light and the ABS lights are on, and stay on until i park the truck at work. After work its the same thing, i can go all the way home with neither light lit on dash, but if i stop and turn the truck off, once i get back in both lights are on for the duration of the trip. it doesnt seem to affect the way the trk. drives or stops..... any help will be greatly appreciated.
Sep 27, 2008 at 6:01 AM
MMPRINCE4000
  • 8,548 POSTS
Have the car scanned with a chassis scanner or ABS scanner. It could be as simple as a loose wheel sensor.
Most autoparts stores scan PCM (powertrain) codes. You will probably have to go to a garage that has a chassis scanner.
Sep 27, 2008 at 6:44 AM
