This is for a 2001 Chevy S-10. The blower motor has 4 speeds. All of them work except the high speed. We've replaced the relay and resistor, but the problem persists. When we direct wire to the blower, it works on high, so the blower should be fine. When we bypass the blower switch, it still has the same problem, with the lower 3 speeds working but not on high, so the switch shouldn't be the problem. Could it just be a bad wire? Running out of options. Thanks in advance...
Dec 6, 2009 at 9:13 AM
