2000 Chevy S-10 Vent to defrost
2000 CHEVROLET S-10
82,000 MILES • 4 CYL • 2WD • AUTOMATIC
LTURNER287
The heat and the air is totally adjustible. Hot and cold.
But it will not move from the vent to the defrost position.
Now more air coming from the vent than the defrost. Moving the knob from defrost to ac it will not change. Happen in the winter. Florida
Jun 24, 2010 at 2:42 PM
BLUELIGHTNIN6
  • 16,542 POSTS
hello and thanks for donating
often when this occurs, it is a failed blend door actuator that prevents the modes from changing. first you will want to check for bad vacuum lines though. a common issue with this vehicle is a rotten/bad vacuum line on the resevoir under hood. it is the black ball looking item on the driver side, by the hood hinge.
Jun 25, 2010 at 12:54 PM
