I'm trying to replace a timing chain on a 2.2 liter engine. My problem is I can't seem to get the cooling fan and clutch assy off. I removed the belt and 4 bolts on the pulley. the pulley is loose but the fan is not. It seems to be attached by a 1.5 inch wide hex nut that spins on a bearing. Any sugestiions? Also I need to know if a 2.2 liter s10 engine is a interferance engine. I'm wondering if I might have bent valves because the chain is broken.
Jun 4, 2009 at 11:30 PM
