2000 Chevy S-10 P1870, P0420
2000 CHEVROLET S-10
10,000 MILES • 4 CYL • 2WD • AUTOMATIC
GLASSRAGEOUS
P1870, and P0420 engine codes, ALSO oil pan leak.,..is it true, you hav to remove engine to fix,,,any other way to fix?
Mar 28, 2008 at 6:42 PM
SERVICE WRITER
  • 9,123 POSTS
What is the oil pan doing? LEaking I assume? If so , Where?
The po420 is a cataylitic converter code that almost always ends up being the converter in my experience. It may also set when there is an air leak in front of the converter.
Mar 28, 2008 at 7:10 PM
2CARPRO JACK
  • 11,533 POSTS
P1870 is "trans component slipping" usually not a good sign. On the brighter side it is easier to get the oil pan out if the trans is out, remove flexplate and it will come out
Mar 29, 2008 at 8:55 AM
