2000 Chevy S-10 Oil Pressure Gauge Erractic
2000 CHEVROLET S-10
24,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOHNLPRICHARD
The oil pressure gauge started flailing back a forth first high then low then leveled out in a higher position than normal. Next day truck wouldn't start, all fuses where checked. Fuel pump not yet tested.Could it be an oil pressure swtch? If so , where is that located. I want to elliminate all possible other things before dealing with the fuel pump. I think there is only one fuel pump and it is in the tank!
Let us pray...oil pressure switch...oil pressure switch. pLease say it could be that.
Jan 21, 2008 at 4:57 PM
JAMIE614
  • 6 POSTS
i dont know what the fuel pump would have to do with the oil gauge but if u want to check fuel pump just get under it and have some one turn the key on u will hear the motor start in t he tank if its workin or spray some starter fluid in the air intake and see if it wants to turn over
Jan 24, 2008 at 9:42 PM
JAMIE614
  • 6 POSTS
and the oil pressure always goin up and down in a chevy every time u hit the gas and it seems when it bout time for a oil change it always low u change it and it back up every chevy i had does this and never had a prob
Jan 24, 2008 at 9:44 PM
