2000 Chevy S-10 Oil Pan Gasket
2000 CHEVROLET S-10
96,000 MILES • 4 CYL • 2WD • AUTOMATIC
JONES1219
I was wondering if you could give me instructions on changing the oil pan gasket
Jan 31, 2009 at 8:13 PM
BRIAN 1
  • 1,030 POSTS
your not gonna like the answer,here is the instructions:Remove the engine from the vehicle. Refer to Engine Replacement .
Install the engine on a suitable engine stand.
Remove the oil pan. Refer to Oil Pan Removal
Clean the sealing surfaces and the oil pan. Refer to Oil Pan Cleaning and Inspection .
Installation Procedure
Install the oil pan. Refer to Oil Pan Installation .
Remove the engine from the engine stand.
Install the engine into the vehicle. Refer to Engine Replacement . I've done a couple,these SUCK to do. good luck post back with any other questions.
Jan 31, 2009 at 8:19 PM
