what you should expect from a valve job...
you can expect the valve guides to have close tolerances with the valve stems.
you can expect the valve stem height to be correct for the spring seat.
you can expect acceptable spring pressure.
you can expect the valve to seal against the seat.
what i will cost will depend on what they have to do.
will the guides need to be replaced or just reamed?
will any seats need to be replaced?
will any valves need to be replaced?
are you pulling the heads yourself, or are you taking the truck to a shop?
Dec 27, 2008 at 4:32 PM
