2000 Chevy S-10 fuel injectors
2000 CHEVROLET S-10
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
BALL79
  • 9 POSTS
2000 chevy s10 4.3 vortec. Injectors are not spraying. Checked
Everything spark,pressure,fuses. What could cause them not to work.
Aug 31, 2010 at 6:51 PM
WRENCHTECH
  • 20,761 POSTS
Is it the power side or the pulsing ground side that's missing?
Do you have spark?
Does your check engine light come on for bulb check when you turn the key on?
If it's a Vortec, how did you conclude that they weren't spraying?
Aug 31, 2010 at 6:58 PM
MADMIKE1735
  • 951 POSTS
did you recently work on this vehicle, if so what exactly did u do...
Aug 31, 2010 at 7:12 PM
BALL79
  • 9 POSTS
Well the truck has been sitting for 3 yrs before I bought it. I replaced the gas tank fuel pump injectors and crank sensor. Just put it all back together now its spitting and shuddering
Aug 31, 2010 at 8:34 PM
BALL79
  • 9 POSTS
I was told to pull it apart and turn key to check the injectors. Also it will run with starting fluid.
Aug 31, 2010 at 8:43 PM
WRENCHTECH
  • 20,761 POSTS
What's your fuel pressure?
Aug 31, 2010 at 8:45 PM
BALL79
  • 9 POSTS
Its pushing in the 55 range..
Aug 31, 2010 at 8:49 PM
WRENCHTECH
  • 20,761 POSTS
That's not enough fuel pressure. 55 is about the bare minimum to run and sometimes not enough. 60 to 66 is the spec and it needs every bit of it.
Aug 31, 2010 at 8:52 PM
MADMIKE1735
  • 951 POSTS
if it runs on starting fluid, it sounds like a definate fuel problem.... i agree, check fuel pressure... if its low, remove fuel filter... you should beable to blow through it freely... if not, then its clogged badly, and needs to be replaced... recheck fuel pressure... it should be in the 55-60 range
Aug 31, 2010 at 8:53 PM
WRENCHTECH
  • 20,761 POSTS
I don't think your not going to see 100 pounds out of this pump even dead headed. Peak will probably be about 70 to 75 dead headed. I suspect yours isn't even hitting 60.
Aug 31, 2010 at 8:57 PM
MADMIKE1735
  • 951 POSTS
after some research i discovered that this engines fuel pressure should be 55-60psi....
Aug 31, 2010 at 9:01 PM
WRENCHTECH
  • 20,761 POSTS
No, the spec is Key On Engine Off 60-66 psi
and it was posted already.
Aug 31, 2010 at 9:04 PM
BALL79
  • 9 POSTS
I change all and completely forgot the filter. I'm going to go pull it right now and check it and prolly just replace it tomorrow. Hey I really want to thank you guys a lot. This is an amazing site. Thanks again guy. I'll let u know what I find.
Aug 31, 2010 at 9:07 PM
BALL79
  • 9 POSTS
Just pulled the filter took everything I had to blow through it. Pick up one in the morn see what happens. Its at 60 on pressure.
Aug 31, 2010 at 10:43 PM
BALL79
  • 9 POSTS
Update.. Its running but very choppy. I've put a fuel pump,injectors,filter,and plugs. Everything is set right as far as pressures and wires. Any ideas on why its running so rough. Anything else I've overlooked.. Thanks
Sep 8, 2010 at 6:52 PM
WRENCHTECH
  • 20,761 POSTS
Any check engine light now?
Sep 8, 2010 at 6:55 PM
BALL79
  • 9 POSTS
Yes lights on. Not sure if I can get a scanner or get it to a scanner.
Sep 8, 2010 at 7:08 PM
WRENCHTECH
  • 20,761 POSTS
That's where you have to start
Sep 8, 2010 at 7:10 PM
BALL79
  • 9 POSTS
Evap control system pressure sensor low.. Is the code I got.
Sep 8, 2010 at 8:29 PM
WRENCHTECH
  • 20,761 POSTS
When did you read that code?
Sep 8, 2010 at 8:30 PM
