Is there a fuel cutoff switch and if there is where is it located?
Sep 26, 2009 at 9:54 AM
BLUELIGHTNIN6
CERTIFIED EXPERT
This car does not have a fuel cutoff sensor only Fords do. Use 2CarPros anytime, we are here to help. Please tell a friend.
Oct 1, 2009 at 7:54 PM
JEREGOT5
MEMBER
1 POST
Engine Mechanical problem
1995 Chevy S-10 4 cyl Manual
where is the reset located on for the fuel pump
Jan 30, 2019 at 2:40 PM
(Merged)
BLUELIGHTNIN6
CERTIFIED EXPERT
fuel pump / oil pressure switch is located on right side of engine, behind alternator. if no power to pump, also check fuse and fuel pump relay.
(Merged)
TNR0788
MEMBER
1 POST
1988 Chevy S-10 4 cyl Two Wheel Drive Manual
Hello, i have to remove my exhaust manifold and my fuel filter n it's hosing are in my way! Can you tell me where the fuel shut off valve is so i can remove the filter and have access to the manifold bolts?
(Merged)
INTERNETMECHANIC
CERTIFIED EXPERT
Hi, there is no shut-off valve. After the vehicle sits overnight without the key being cycled or started, there shouldn't be much pressure if any. That doesn't mean fuel won't try to run out.
