2000 Chevy S-10 Code 1870
2000 CHEVROLET S-10
57,000 MILES • 4 CYL • 2WD • AUTOMATIC
BIGFOOT55
  • 4 POSTS
Took auto back on 11/09 for oil change and all was well (trans fluid checks). However, for about 6 months I have noticed that when shifting from 1st to 2nd it is jerky & at times seem like it does not go into overdrive. Just this month the "Serv. Eng. Light" has came on twice and I had it read. Code is 1870. The RPM bounces in overdrive. Most of the time the auto runs great. Took it to Dealer and was told needs new Trans. The next week took it to Mr. Trans. and was told Torque starting to fail and now I have a rear seal leaking on Trans. and fluid was low. I have read the Service Bulletin 01-07-30-023B which states the cause may be due to wear in the control valve body. Mr. Trans. said that fixing the control valve would not fix the problem. Please help. Do not know WHO to believe. Should I take it to another shop and see what they say. Most of time car drives good except the RPM's go up and down frequent.
Mar 17, 2010 at 9:08 PM
WILLIAMBENEDICT4JESUS@ATT
[quote:10f68c482b="bigfoot55"]Transmission problem
2000 Chevy S-10 4 cyl Two Wheel Drive Automatic 57000 miles
Took auto back on 11/09 for oil change and all was well (trans fluid checks). However, for about 6 months I have noticed that when shifting from 1st to 2nd it is jerky & at times seem like it does not go into overdrive. Just this month the "Serv. Eng. Light" has came on twice and I had it read. Code is 1870. The RPM bounces in overdrive. Most of the time the auto runs great. Took it to Dealer and was told needs new Trans. The next week took it to Mr. Trans. and was told Torque starting to fail and now I have a rear seal leaking on Trans. and fluid was low. I have read the Service Bulletin 01-07-30-023B which states the cause may be due to wear in the control valve body. Mr. Trans. said that fixing the control valve would not fix the problem. Please help. Do not know WHO to believe. Should I take it to another shop and see what they say. Most of time car drives good except the RPM's go up and down frequent.[/quote:10f68c482b] FIRST MAKE SURE FLUID IS FULL. THERE IS AN UPDATE KIT FOR THE VALVE BODY THAT STEEL SLEEVES ARE INSERTED TO PREVENT PREMATURE WEAR SO THERE IS NO LEAKAGE BY THE VALVE. THEREFORE ALLOWING CONVERTER TO LOCK UP. COULD ALSO BE A TPS PROBLEM. CAN CHECK THIS BY SIMPLY REMOVING TPS TO SEE IF SPRING TENSION IS GOOD.
Mar 18, 2010 at 8:35 PM
