2000 Chevy S-10 changing spark plugs
2000 CHEVROLET S-10
77,000 MILES • 6 CYL • 4WD • AUTOMATIC
BIGMARK17
I am having difficulty changing the Number 3 & 5 spark plug hard to reach due to steering column
Sep 16, 2009 at 6:45 PM
JESSE.TYLER.24
  • 6 POSTS
I had the same problem. It is simple to remove the steering column follow the steering shaft down to the boot. Once you "un-button" the boot it's simply a matter of loosening the single bolt. Once removed pull back on the steering shaft (if it's difficult use a large flat head to break the seal or turn the steering wheel a little) and pull until it reciever clears the splines. With this out of the way I chose to go beside the driver tire under the rubber wheel skirt and it was finished in minutes.
Oct 1, 2009 at 2:47 PM
