1999 Chevy S-10 popping sound in front end
1999 CHEVROLET S-10
165,000 MILES • 4 CYL • 2WD • MANUAL
KENAS
while sitting still i can turn the steering wheel and i hear a popping sound usually at about the end of the turn. This is while sitting still. could it be the ball joint or bearing? I would appreciate your input very much
Oct 6, 2009 at 4:15 PM
It sounds like a ball joint problem. Lift the vehicle by the frame. Make sure it is safe, and take the front wheels abot 8 inches off the ground. After you do that, place a pry bar under the tire. See if there is up and down movement in the ball joints.
Let me know what you find.
Oct 17, 2009 at 5:17 PM
