1999 Chevy S-10 Internal Clutch will not engage
1999 CHEVROLET S-10
15,000 MILES • 4 CYL • 2WD • MANUAL
DUCKYKINS18
my clutch line had started leaking, I fixed the line, started to bleed the line, and now clutch will not engage.
Apr 20, 2008 at 3:16 AM
BMRFIXIT
  • 19,053 POSTS
Top off reservoir with new DOT # brake fluid
have an assistant depress and hold clutch peddle
open bleed screw let air out
repeat until all air out of system
check and refill fluid as needed
if still unsuccessful
you can try this
remove reservoir cap
pump pedal very fast for 30 sec
stop to allow air to escape
repeat procedure until successful
Apr 20, 2008 at 6:23 AM
DUCKYKINS18
[quote:3c36d9c175="BMRFIXIT"]Top off reservoir with new DOT # brake fluid
you can try this
repeat procedure until successful[/quote:3c36d9c175]
ok, ive tried that and my clutch still wont engage, and it feels like there is no pressure to the clutch, is there an adjustment i have to make?
Apr 21, 2008 at 8:01 PM
BMRFIXIT
  • 19,053 POSTS
no adjustment u need to get the air out
Apr 21, 2008 at 8:17 PM
