S-10 Blazer - 4-wd
Vehicle has a vibration that is most noticable on passenger side floor board starting at about 25 mph and remains steady until about 40 mph. Is worst when accelerating and/or at steady speed. Dissappears when slowing down. R or L turns have no affect.
Repairs made recently before problem started include:
New upper and lower ball joints, both sides.
Upper a-arm bushings, both sides.
Full front end alignment.
New brake rotors and pads.
New tires.
Repairs made after problem started include:
New RH outer wheel bearing assy - old bearing was found to be dry.
Reman CV shaft assy - found grease leaking past clamp on inner slip joint boot, also shaft wobbled as wheel was turned. Roller bearing inside axle shaft tube is good. Axle shaft not bent.
Check motor mounts - OK
What am I missing?
New tires.
What am I missing?
Dec 7, 2009 at 11:45 PM
