1998 Chevy S-10 White smoke coming from the exhaust?
1998 CHEVROLET S-10
140,000 MILES • 4 CYL • 2WD • MANUAL
CHEVY619
MEMBER
1 POST
FOLLOW
I was wondering if you can suggest any problems that might cause the white smoke from the exhaust? Head gasket? Pistons?
Mar 5, 2008 at 7:08 PM
SERVICE WRITER
CERTIFIED EXPERT
Typically it is coolant burning. Maybe headgasket, intake gasket? Sometimes you will see bubbles coming up through the radiator that are from a headgasket leak.
IF you pull the plugs and pressure test the cooling system for about 5-10 minutes, then spin the engine over with the plugs out, coolnat may shoot out the plugs hole to help confrim the leak.
