1998 Chevy S-10 Unknown sounds from transmission?
1998 CHEVROLET S-10
USAJOEMILLER2005
Transmission problem
1998 Chevy S-10 6 cyl Two Wheel Drive Manual 159.00 miles
I have a chevy s10 manual transmission and every time I start out it makes like a rattling noise is that the cluch or loose parts?
Jan 8, 2008 at 11:35 AM
BMRFIXIT
  • 19,053 POSTS
[quote:438c421f0f="usajoemiller2005"]Transmission problem
I have a chevy s10 manual transmission and every time I start out it makes like a rattling noise is that the cluch or loose parts?[/quote:438c421f0f]
check the exh. system
check mounts
Jan 9, 2008 at 6:43 PM
USAJOEMILLER2005
[quote:5de9ccc91c="BMRFIXIT"][quote:5de9ccc91c="usajoemiller2005"]Transmission problem
I have a chevy s10 manual transmission and every time I start out it makes like a rattling noise is that the cluch or loose parts?[/quote:5de9ccc91c]
check mounts[/quote:5de9ccc91c]
Well i did nothings loose i think its in the trans. becuse every time i drop the cluch it does that and its when im in first gear.
Jan 16, 2008 at 2:19 PM
BMRFIXIT
  • 19,053 POSTS
When you have the noise stepping down on the clutch will make it fade away
I’m thinking clutch bearing
Jan 16, 2008 at 6:44 PM
