1998 Chevy S-10 Missing/not running right
1998 CHEVROLET S-10
140,000 MILES • 6 CYL • 4WD • MANUAL
CODYIRELAN545
My pickup has a weird problem. When it starts up it idles just fine but when any amount of throttle is applied it will bog down, miss, and kind of act like its choking to death. It does this for a few seconds and then the rpm's come back up. Also while im driving around at a constant speed with a small amount of throttle applied it does the same thing and misses and shakes the truck very violently. The weird part of this problem is it seems to get alot worse on days when it is raining or has rained recently. On nice days when it is hot and dry out the truck still has a barely noticeable miss. Hopefully someone can help me out with this, thanks.
Sep 17, 2010 at 4:14 PM
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Sep 18, 2010 at 12:24 AM
