1998 Chevy S-10 hand brake
1998 CHEVROLET S-10
145,000 MILES • 4 CYL • 2WD • MANUAL
PINSAM
the parking brake pedal on my 1998 chevy s10 has worn out the gear teeth shall we call it so i cant set my parking brakes.can it be replaced if so how?
Apr 13, 2008 at 3:32 PM
MIKE H R
  • 3,094 POSTS
back off the adjusting cable under the vehicle detach the parking brake pedal assembly from the kick pannel { 3 bolts } . Pull the plug on the end of the cable out of its hole in the ratcheting cam. Squeeze the tangs on the parking cable ferrule and slip the cable out through its bracket. After getting another {new or used} re-install in reverse.
Apr 14, 2008 at 10:18 AM
